What happens to photos included in a survey
747
03-11-2022 06:55 AM
PaulHallett1305
Just a couple of questions around Survey123
I am assuming you create a Hosted FeatureLayer on the Hosting Server when you create a survey and post its results.  How do you find the size of it, or where is the survey data stored?
Also, if you add photos that you take, to a survey, where are these stored when you upload the survey?
I can't find documentation to show how this architecture works.
Katie_Clark
The information submitted through the survey is stored in the Hosted Feature Layer associated with the survey.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
