I created an ArcGIS Survey123 survey for the public to request addresses for utility purposes such electric / water meters. The survey was built in ArcGIS Survey123 Connect (template version 3.22, revision date 2/26/2025). The survey allows a user to input multiple points along with multiple attachments.
I created a Web Hook via Make and generated a workflow that generates a Trello card when someone submits a request for a new address. This process has been working without issue for over a year. My organization is now using Microsoft 365. I want to migrate our workflow from Make to Power Automate to take advantage of things like sending an e-mail instead of creating a Trello card.
I have hit a snag; using the trigger (from the ArcGIS connector) "When a survey response is submitted" I am able to select the survey however when I try to access content from the submitted survey, I get a message stating that no dynamic content is available. I also noticed in AGOL that no web hook is created for the survey.
I created a new simple survey in ArcGIS Survey123 Connect to test. I was able to see this survey and see the dynamic content in Power Automate. I'm wondering if there is an issue with the survey itself. I have attached the excel file of the survey.
