Watermark using photo from device option
1076
09-11-2019 12:18 AM
ChrisRoberts2
Hi All
I have noticed that if use the folder option to use a photo from the device.
Then the watermarking isn't applied.  The watermark is simply based on questions answered and does work if you "take" the photo using the camera option.
Is this by design or is there something I am missing.
Cheers
Chris
Jing_Sun
Hi Chris,
It appears that this is the function by design.
The Survey123 for ArcGIS - Watermarks says:
Starting with Survey123 for ArcGIS version 3.5, you can apply text and image watermarks to new photos taken with the Survey123 field app camera. Watermarks can not be applied to existing photos on the device.
Cheers,
Sun
ChrisRoberts2
Thanks Sun
Didn't look there for the answer.
Cheers
Chris
