Very poor performance with Survey123 barcode scanner in comparison to other apps
7610
13
12-09-2019 03:01 PM
by Anonymous User
Not applicable
I am working on a Survey123 form where one of the essential requirements is the ability to scan QR codes that are attached to various assets in the field. I am hoping that there is a way to improve the QR code scanning capabilities of Survey123 as the performance is very poor compared to every other scanning app that I have tested (detailed results below).
The QR codes that we need to scan are printed on metal plates that are somewhat reflective. I am having an incredibly difficult time scanning these bar codes within the Survey123 app built-in barcode scanner. I am finding that these tags are almost impossible to scan within the app with almost any amount of reflection. This is a huge problem for field use where light sources are variable.
Other barcode scanning applications do not have this problem. I have created a comparison video with a constant light source showing the scan speeds between the first 8 apps that appear on the IOS app store when you search "Barcode Scanner". Here is a detailed breakdown of the results.
0:01 to 1:08 - attempting to scan the QR code within the Surbey123 app for over a full minute. The scan does not register the QR code.
1:12 - to 1:20 - Scanning with 'QR Reader' app. This scan took 8 seconds and was by far the slowest other scanning app (other than Survey123
1:25 to 1:27 - Scanning with 'SkanKey' app - this took under 2 seconds to correctly scan the tag
1:30 to 1:31 - Scanning with 'Bakodo' scanner app - correctly scanned in under 1 second
1:39 - 'QR Code' scanner app scans the app in under a second and brings up the correct result as the app opens (near instant scan speed) before it even initialized the camera viewfinder view.
1:48 to 1:54 - 'QR Scanner' app scans the code in 6 seconds
2:02 to 2:04 - Free version of 'QRScan Pro' app scans the tag in under 2 seconds
2:13 to 2:18 - 'Scanner' app scans the code twice, in a fraction of a second each time
2:22 to 2:28 - 'Qrafter' app scans the code in about a second.
2:35 to 3:33 - I open Survey123 again to attempt to scan the code. This time I move the light source around until I get Survey123 to get a correct scan of the tag. This takes nearly a full minute and only achieves a correct scan when there is nearly no reflection on the tag.
Why is this capability so poor in Survey123 compared to seemingly every other application?
Specs: this app was created in Surey123 connect. This specific test was done on an A1954 6th gen model iPad, iPad OS 13.1.3 with Survey123 version 3.6.157.
This problem is not limited to IOS - I have tested the Survey123 QR code scanning with Android (Galaxy S8) and Windows 10 (Surface Go tablet), and on other IOS devices with very similar poor results.
by Anonymous User
Not applicable
Hi @CarlosChamusca,
Many enhancements has been made to barcode scanning since 3.10 and are available in the 3.12 release. We have not had much feedback since then about other customers having issues scanning barcodes, the recent update in many cases have made a big improvement.
Having a look at your sample.jpg, the quality of the QR code is not very clear, I am not sure if it is the plastic, or it is dirty, or the printed qulaity of the QR code. It appears the black parts are not solid where they should be, there is many white specs all over the black parts. This will significantly affect the chance of a successful scan.
It is not possible to use an external QR code (barcode) reader and pass the results to Survey123 application into a text field, we do not support such a feature.
We do plan to do more improvements to the barcode scanner in future, such as upgrading the inbuilt library and framework that is used, however this is significant developement work and not currently planned for a near future release.
Regards,
Phil.
jwelty_USGS
@Anonymous User Found this older thread and wanted to reply as we are currently having some issues scanning small barcodes (all numeric, black barcodes on a white background). We believe we have traced the issue to glare from the lights. When there is some glare on the code Survey123 struggles to read the code. If we rotate the vial or turn the lights off it reads much faster. However, another app I just downloaded read it just fine and from further away even when I ensured the max glare possible. Are there any more improvements coming to the barcode scanner functionality? Having to get it right for 1 or 2 codes is not a big deal, but our folks are scanning hundreds of codes at once. Having better reader functionality would be nice.
by Anonymous User
Not applicable
Hi @jwelty_USGS,
We are currently investigating alternate barcode libraries that are more advanced and provide faster and more accurate barcode scans, similar to other barcode scanning apps that are available in the app stores. We are hoping to be able to integrate one of these into Survey123 in the future and replace the current library being used. Once we have this available for testing, please keep an eye out on the Early Adopter Community for early testing and feedback.
Regards,
Phil.
jwelty_USGS
@Anonymous User - Excellent, thanks for the update!
