Using the Survey123 Map Widget consumes credits?
2354
08-05-2020 07:52 AM
AntonioSaavedra
Good morning!
Using the Survey123 Map Widget consumes credits? Example to locate your position.
Thanks
BenTurrell
Hey Antonio Saavedra‌,
You can see a list of functions that use credits here: Understand credits—ArcGIS Online Help | Documentation
If you are referring to the survey123 app locating you on the map I don't believe that uses credits. I believe the only thing that uses credits is generating survey123 reports.
Thanks
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
BenTurrell
Thanks
Ben
AntonioSaavedra
Ben,
Thanks very much!!!
