Using Power Automate to Email a Report
1897
05-13-2024 12:14 PM
JoshHabel
I am having a problem setting up a Power Automate Flow to create and email a Survey123 Report.  Having never done this before, I've set up this flow based on what I could find online in the various blogs.  The first 3 parts works fine. It will create the report and uploads it successfully to one drive.  I can even open the pdf from there.  Problem is when the reports gets emailed as an attached pdf, you can't open the pdf.  All you get is there error.  I'm at a loss as to what the issue is here.  Does anyone know how to resolve this?
RobertAnderson3
MVP Regular Contributor
Can you expand the details on the email action? This is how I have it set up to sent the attachment in my flow.
JoshHabel
Robert,
Mine is set up the same...
RobertAnderson3
The only thing I notice different is that around the dynamic content elements you have quotes, where as in mine I do not. I wonder if that's making the difference?
