Hello All,
This is my first post in the community so any help would be appreciated. I am in Nebraska where many counties have a contract with gWorks to map County Assessor data for every parcel. I would like to have a map of a community where I can select a parcel on the map and a housing assessment survey I have created is available in a pop-up to be completed. It would be ideal if this can be completed on or off line.
Thanks in advance for any insights you might have for me. I am providing a link to steps I have attempted to follow, but have not seen any change in my survey.
https://support.esri.com/en-us/knowledge-base/how-to-embed-a-survey-form-and-edit-existing-data-from--000021897#:~:text=Note%3A%20A%20survey%20created%20in,select%20Open%20in%20Map%20Viewer.
If offline is a requirement, you likely want to integrate with Field Maps so you can download the map for offline use and then launch from there into S123.
Very general guide:
Thanks Abureaux. I will attempt your steps provided. I'm thinking offline will help making capturing the data more efficient in low cellular signal locations when capturing survey data. Do you think I'm on the right track with the offline aspect?
Yes. Offline workflows are common in Field Data collection. We have many sites in the "middle of nowhere" (e.g., Northwest Territories) where cellular data isn't an option, so offline workflows are essential for us.
I didn't mention it before because I don't think it will be helpful in your workflow, but the Survey123 Inbox is another great offline option (I use this a ton).
Signed in members can post, follow updates, and more. New here? Register a free account.
