Using a Survey123-created hosted feature in Field Maps
563
07-07-2023 12:22 PM
JovanaB
Hello - i have a new hosted feature that was initially only created through a new Survey123 survey (created in S123 Connect). I am trying to use that feature layer within a web map that will then be used for editing in Field Maps, but for some reason I cannot tap on the point in Field Maps to open up the attributes and go to edit. Nothing happens - it is as if the point feature is unresponsive in Field Maps.
Is this some sort of bug or is this not a capability to use the hosted features that are created from Survey123 surveys in Field Maps?
DougBrowning
MVP Esteemed Contributor
Yes it can be done.  In the web map do you have popups turned on?  That is my guess.  You can also set which fields they can see, edit, etc.
DougBrowning
JovanaB
So after some fiddling on the settings tab, it was the issue of "allow editing" to the feature (totally my bad on that!). It is still strange I wasn't able to even see a popup on the feature even though the popups were turned on (that was one thing I did check!), but it all works now. Thanks for your quick reply @DougBrowning !
