I've added a body::esri:inputMask to a decimal type pH value in my form using the documented sample "B9.99;-" The field should be optional but adding the mask makes it a require since the form never validates when the value is left empty. In addition to this the pH value has a relevant constraint where it only shows up given a specific condition so even when the attribute is not visible the survey123 returns an invalid warning. Also tried adding a default value of 0 but continued to get the same error.
Any idea as how to solve this?
