Use labels not names without calculation Survey123
926
03-03-2022 03:35 AM
KennethLindhardt1
I just want to confirm that there is no way to show the label and not the name, without adding a new calculation field.
We are creating a survey with a lot of select one quistions. Then we have another survey that are pulling in all the data in a read only survey, so basically just a document. To make it more readable I want to remove the box graphic drop down, but just show plain text, by changing the field in the second survey from select_one to note. I'm using a submission_url and this is actually working, except the fact that it is showing the name and not the label in the Survey.
I really want to prevent to add additional 50 fields to the feature service in a already 370 field service..
So I want to have the same functionality as jr:choice-name but without the calculation field.
Possible?
Thanks.
BrandonA_CDPH
@KennethLindhardt1 - you could do this using the ESRI:FieldType Null method described here: ESRI Custom Columns  - about a third of the way down.
I see this and hidden questions working well.  Something like a hidden, read only question that pulls in the original data, then a null question that displays what you want to show. No additional fields added to the feature service.
KennethLindhardt1
Thank you Brandon, that was very clever and very useful for this.
BrandonA_CDPH
You're welcome.  Glad it's going to work for you. 🙂
