Use a link to navigate to a record in a repeat?
1416
7
04-28-2021 11:11 AM
Strahanjen
Is it possible to create a link that would navigate directly to a particular record in a repeat? Here's the use case: Biologists enter fish observations summarized by species including length min/max, weight, number of fish, etc. I use a custom Javascript function to display the entries in a tabular format. The user would like to be able to click on a species in the table to automatically jump to that record in the repeat in order to make edits to the values. Might this be possible? If so, how would I structure the link?
IsmaelChivite
Esri Notable Contributor
Sorry. Not possible.
Strahanjen
Ismael, thanks for the response. Do you know of another option for making quick navigation between large numbers of records in a repeat possible?
Jennifer
DougBrowning
MVP Esteemed Contributor
If you long press the next arrow it will go to the end of that helps.  But I am thinking that many repeats in one form you may want to think of a diff design.  Like a parent and each form is a child - so multiple forms vs multiple repeats.
Strahanjen
Thanks for the tip. I may resort to using a grid for filling out the fish entries instead. The problem is the tablet is small, and I have 8 columns for each fish observation. Users want to see all of the fish observations submitted, at a glance, and also to be able to change a measurement if desired.
DougBrowning
I do summary pages for the crews so they can see any weird values at a glance.
I even give warning messages in red
But no you cannot edit right there since that would be having one field in two places.  They still have to go find the issue.
You prob want to grow the repeat down.  Upvote these ideas (but I heard its really hard in the UI).  As you can see there are a lot of idea posts in these links.
https://community.esri.com/t5/arcgis-survey123-ideas/tally-sheet-format-for-repeats/idi-p/938975
https://community.esri.com/t5/arcgis-survey123-ideas/table-view-for-repeats/idi-p/938544
thanks
Strahanjen
Nice! Do you use Javascript code to generate those summary pages? I'm assuming you're pulling information from the repeats to build the summary?  If so, I'd love to see a snippet of your code.  Thanks very much for your guidance!
DougBrowning
I just use min, max, sum, and join.
