URL in Survey123 based on a calculation
607
08-07-2024 09:28 AM
MyEthiopia
I am trying to create a clickable link in survey123 based on a previous answer. The parcel id populated in a previous question will be used as the key value in beacon. I am not sure if survey123 allows a html href code. If not, how can I create a link that can be clicked and is dynamic.
MyEthiopia
It works in survey123 app but not survey123 online. Does someone have a work around or should I just use ArcGIS pro field calculator?
MyEthiopia
I was able to figure it out. It’s now working on both the app and online 🥳🎊
