Updated Survey123 now I can't Republish my Surveys
911
04-25-2018 12:31 PM
DanielHunter
I updated my Survey123 Connect software last week and now I can't republish the survey without being prompted that the service is not compatible.  Anyone have a work around?  The table structure is def. the same.  The survey was published months ago with an older version of the software (likely pre 2.0).  I was hesitant to upgrade because of this very issue!  Any assistance is appreciated.
Dan
JamesTedrick
Esri Esteemed Contributor
Hi Daniel,
There have been a number of changes between the previous version you are using and current Survey123.  Given the message you are seeing, it is most likely that the form_id value is mismatched to teh layer name of your feature service (See Settings—Survey123 for ArcGIS | ArcGIS ).  Aside from hat, you may see advisories to create fields for note questions in your survey; in order to avoid that, you can either remove teh name values for notes or set their esriFieldType to null.
JamesTedrick
Hi Daniel,
DanielHunter
James,
Thank you for the prompt reply.  That worked.  While I had the Form_ID previously populated with spaces in it between words (e.g. Buckeye Lake GeoTech Production).  The FS layer name contains underscores instead of spaces (e.g.  Buckeye_Lake_GeoTech_Production)  Updating the Form_ID to include the underscores resolved the problem.
Thank you,
Dan
