I use a csv file in the pulldata function to retrieve address data for a site. In development I named this file address_sample.csv. There are over 80 sites however, with multiple sites possibly being surveyed at any given time, so I'd like the file to be named after them, something like chicago_address.csv, liverpool_address.csv, nairobi_address.csv, etc. This would involve somehow dynamically changing the file name in the pulldata function, as far as I can tell. Is this possible? Thanks.
It works for me if I give it a field. I have the calc for the name in the field then give that to pulldata.
pulldata(${SpeciesListName}, ${WetlandIndicatorStatusColumn}, "name", ${Species})
Maybe you added .csv to it? You should not have it be just the name. And note it IS case sensitive.
Hope that helps
Not using the .csv extension. Will try putting it into a field like you suggest. Would be nice if S123 could read the media folder and select a csv file with 'address' in the file name.
Yes that is what my form does. I pass a state in from Field Maps then it selects the right species list to give them using a calc.
It for sure works. Try and field and make sure the case is correct.
