Unix time calculation not populating correct date in survey
956
03-20-2024 06:16 AM
dwold
I am trying to convert Unix time to mm/dd/yyyy in a survey. I am pulling data from a feature layer into this survey using the pulldata("@layer"). I tried following this document but for some reason, my calculations are not population the correct date.
Feature Layer Dates I am pulling from:
Survey:
Web format:
@IsmaelChivite anything you see in the table that isn't allowing the conversion to be made?
DougBrowning
MVP Esteemed Contributor
On those 2 note fields that get the times try setting the bind:type column to int.  It will treat those note fields as string in the web app by default.  This usually leads to a cocat vs a +,  Never seen it on divide but worth a shot.
Hopefully that does it.
dwold
thanks @DougBrowning for the suggestion. I appreciate it! Unfortunately, that didn't do the trick. It's very puzzling why it won't convert.
DougBrowning
Did you set the bind on the hidden fields line 12 and 13 also?
dwold
@DougBrowning still getting some funky output after changing the blind type to int. Very puzzling why it won't convert.
DougBrowning
I think you use unix time for calcs but for display you need to format it I think?
format-date()
Fits an existing date or time value to a defined format.
format-date(${previous_time}, '%H:%M')
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#ESRI_SECTION2_AF58C02...
