Unable to submit S123 form published from 3.24.30 after October 2025 ArcGIS Online update
155
10-23-2025 08:49 AM
SharonUngerer_DNREC
Has anyone else seen this error or found a work around?
[{"id":0,"addResults":[{"objectId":-1,"uniqueId":-1,"globalId":"{4A5C33C6-4CB8-4891-846A-C9C51EBE6F6C}","success":false,"error":{"code":1000,"description":"String or binary data would be truncated.\r\nThe statement has been terminated."}}]}]
I have not edited the field lengths or data in ArcGIS Online.
There are no repeats or calculate questions.
I've submitted a ticket and will post solution if esri is able to fix.
Neal_t_k
Do you have any hidden fields that might calculate an answer bigger than the character limit.  I believe that error code has to do with an answer that is too long.
