Unable to edit a GDBF exported from Survey123
756
07-31-2019 08:24 AM
Environnement_1Lausanne
Hello,
I created 2 Survey123, one with and one without relational databases.
If I export the data of the very simple Survey123 in GDBF, I am able to add the data to an ArcGIS Pro project. And I am also able to modify the attributes.
If I export the complex Survey123 with attachements and relational DB, I am able to add the data to an ArcGIS Pro project but unable to modify the attributes.
Is there a wordaround to be able to modify the attributes of features stored in a GDB ?
Thanks in advance,
Tags (3)
Shwu-jingJeng
When you mentioned that you are not able to modify the attribute table with complex survey you export, did you receive any error message or warning? Could you also share the problematic fgdb you are having issue with?
Hello,
I didn't receive any warning or message. I have attached the fgdb to my main message if you want to check it
Thanks a lot !
DougBrowning
MVP Esteemed Contributor
I can edit this GDB no problem.  Is it a certain field?  Are you hitting enter after you edit date?  Do you have a license that can edit?
Hi ! I managed to edit the GDB but had to activate a Standard licence instead of a Basic one.
