UI Glitch allowing for surveys to send prematurely
566
09-25-2024 08:58 AM
GraceFabry_Santos
Hello!
I am building a survey, using relevancies and the pages style to display one question per page at a time. I am encountering an issue that the survey is able to be sent prematurely without satisfying the relevancies. I believe it has to do with the user interface rather than the xls form.
When answering a fill in the blank question the footer banner moves above the device's keyboard. Once typing in a valid response the check mark appears and the survey is able to be sent rather than going to the next question. When I swipe the keyboard away the check mark then becomes an arrow allowing me to advance to the next question. I have tested this in both Apple and android devices.  Only the android devices encounter this glitch. Any insight into this would be greatly appreciated.
abureaux
MVP Frequent Contributor
Have you brought this up with Esri Support yet? Sounds like it could be an issue with the android app.
