Truncated Error - Adjusted field length etc., still having issue
1067
01-30-2023 01:50 PM
JAbbott
I was building out a form with repeats and have a Repeat Summary field that concatenates the responses into a digestible format for review. Long story short, it displays fine in connect when testing out the question, and after pushing it up to the web form, it will give the truncated error. I've adjusted field lengths to accommodate responses (it's at like 5000 characters, which it'd never run into) and it still throws the error when trying to submit.
Any help is appreciated.
PS- I can clean up and anonymize the XLS if that'd help.
IsmaelChivite
Esri Notable Contributor
Try the following: Go into the esriFieldType column in your XLSForm and set the value of your repeat summary field to null. Publish and try again in the web.
JAbbott
Hi @IsmaelChivite thank you for the response. I still ran into the error. Attached is a snippet of the form. I just pushed this up and tried submitting and ran into the same truncating error, so pretty positive this is the area of the form that's giving me issues. Thanks again.
