I am working on a survey that includes translations to Spanish, French, Arabic and Swahili. I have the labels, hints, etc all set up for those and they appear to work fine.
I asked somebody to submit a response in French and noticed that the values are stored in the feature layer in French. Is there a way to automatically translate them so I only see English answers in the feature layer? I've set up a report template and Power Automate flow that sends a report and the ideal situation is to not have the recipient spend any time translating.
You can try the beta text analysis feature:
In this case, once the user complete inputting the French text, it will automatically translate to English and save to the hidden text question.
@ZhifangWang Thank you for the tip. With the help of Support I was able to implement this in Connect and get the translation(s) to work.
For others wanting this you for sure need to go log into Survey123 and select Organization > Settings > Extensions > turn on Enable the Survey123 assistant
You may also need to log into ArcGIS Online and select Organization > Settings > AI Assistants > turn on 'Allow use of AI Assistants...'
