The web map that created when the new survey published
653
09-14-2022 03:16 PM
YukoYokozawa
We are cleaning up our portal contents and wondering if I can delete the web maps created when I published the forms.
Katie_Clark
I don't think that should be a problem if you haven't been using those web maps. I almost always uncheck the option to create a web map when initially publishing a survey anyway.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
YukoYokozawa
Thank you very much, Katherine. I never noticed there is an option to turn it off! Now I can delete all the maps and will turn the option off.
