The survey is not accessible or does not exist.
16975
41
02-23-2022 06:14 AM
UğurBaranSarıbaş
Hi, after the last update received in Survey123 connect (3.14.256), several Survey form's item details are not accessible in our organization. Please see the screenshot below.
Tags (3)
2 Solutions
IsmaelChivite
Esri Notable Contributor
Thanks all. We are investigating this issue. We are going to roll back momentarily to 3.13 until we can test a fix with 3.14.
by Anonymous User
Not applicable
Hi @UğurBaranSarıbaş
This issue has now been resolved and the Survey123 website has been updated to 3.14, with the noted issue above now resolved. Please test with you surveys again.
Regards,
Phil.
BatesRambow
Same issue here. Republishing the surveys does not help. Console shows CORS errors, but there is nothing that has changed on our Portal end in the last 24 hours.
Also, when trying to access the item directly from Portal rather than the Survey123 site, we get a slightly different error, stating the .webform file is missing.
PortalAdmin1
Seeing the same issue internally. Many surveys across multiple owners. Getting CORS/header errors in chrome: whenever trying to view a survey through survey123.arcgis.com
CamMuller
Also received this issue today on multiple environments, both locally and on client environments. I have published from Connect Version 3.13.249. Tested surveys on version 10.8.1 as well as 10.9.1 of ArcGIS Enterprise.
Also tested with CORS enabled and disabled on IIS, as well as Portal Allowed Origins defined. Unfortunately none of the above has resolved the issue.
aland
Same issue being seen with our Teams.  Across multiple portals.  Problem is systemic (mostly) across survey's published prior to the Survey123 update yesterday.  New survey's published today behave as expected.  No changes w/respect to origins or CORS settings on our end.
ldurland
Same here.
Katie_Clark
MVP Regular Contributor
Yikes! I'm glad I saw this post, because I was about to update....hopefully Esri can shed some light on this soon?
@JamesTedrick @IsmaelChivite Is Esri aware of this issue?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
by Anonymous User
Not applicable
Hi @Katie_Clark,
Regards,
Phil.
abureaux
MVP Frequent Contributor
Same here. Seems like this is on Esri's end. Just got off the phone with support. They are still trying to figure this out.
Edits:
Just to toss this out there. Support had me try adding "Access-Control-Allow-Origin" to IIS. This actually made the problem a little worse so I removed it.
Also, as others have mentioned, this is almost at random. I have surveys I created back-to-back that are almost identical. Some work. Some don't. Republishing doesn't help either, so the issue is something tied to the surveys.
I published with Connect only. I used 3.13 until today when I updated to 3.14, but no change.
Seems like we need to wait on Esri to publish a fix.
BatesRambow
Some more insight into our issue. As others have mentioned, the console shows a CORS error but our CORS settings are completely open. Also if you watch the network traffic while attempting to open a survey detail page, you can see many successful requests and a single failed request. CORS issues wouldn't allow some requests to succeed and others fail in this manner.
I dug into the failed request. It's the `/search` endpoint searching for the ArcGIS Online Vector Basemap group, as its url exists via our Portal:
Wondering what other people are seeing in their network traffic.
