The date field in Survey123 site does not open, browser cache has been cleaned. Any solutions?
1777
6
07-26-2017 01:15 AM
AdministratorAGOL_ODIMM
ZhifangWang
Hi Igor,
If
  1. the Data page worked for your survey before 2.3 release
  2. your survey contains select_one question which has only one choice item in the choice list
then we are working on a hotfix for 2.3 release.
Otherwise, can you please provide more information about the survey? Such as the XLSForm file if available.
JonathanPendleton
Hello, I am having this exact issue. Upon closer inspection, I do have a select_one question which has only one choice item in the choice list. How soon can we expect the hotfix?
ZhifangWang
Hi Igor Roșca‌, Jonathan Pendleton
The select_one question with only a single choice item issue has been fixed on the website, can you please have a try after clearing the browser cache?
Please let us know if the fix works for you.
JonathanPendleton
It has been fixed! Thank you very much. I was getting worried I wasn't going to be able to get to my data.
ZhifangWang
Hi Jonathan,
Glad to hear the fix works for you!
Please don't be hesitate to give us any feedback if you encounter any issue
Thanks a lot Zhifang, now everything works fine!
