The custom feature service submission_url is not compatible with this survey
847
02-24-2023 12:55 PM
Eggnoggy1
I am trying to create a survey built on an existing and hosted feature layer. I seem to be able to set it up in Excel, but when I try to publish I keep getting an error:
The custom feature service submission_url is not compatible with this survey. Fields not found in the feature service: 0.
My process is to open ArcGIS Survey123 Connect on my desktop. Click on + New Survey. Select Feature Services. Locate the feature layer, click on it, then click Create survey. I setup the Excel form, save it, it looks right in Survey123 Connect. But it never publishes. I keep getting that error.
I have checked Enable Editing and Enable Sync (required for offline use and collaboration) in settings in my feature layer. Also Public Data Collection is checked as well.
I also tried entering the name of the form and the form_title and the form_id in the settings tab in the Excel worksheet and no change.
Any ideas?
ZacharySutherby
Hello @Eggnoggy1
What version of Survey123 Connect are you using? If you are using 3.16 try updating to the latest 3.17 release of Survey123 Connect.
https://apps.microsoft.com/store/detail/arcgis-survey123-connect/9PMST5C0DLST?hl=en-us&gl=us&rtc=1
https://www.esri.com/en-us/arcgis/products/arcgis-survey123/downloads
Thank you,
Zach
Eggnoggy1
That was it, thanks.
