Survey123 working with a table that is in a AGOL service with a related featureLayer
2391
7
04-12-2017 07:37 AM
NickToscano
I have a service in AGOL that has a FeatureLayer and a Table.
I took the time to make the table have ID:0 and the FeatureLayer is ID:1.
Regardless when I point Survey123 at my service it only wants to write to the FeatureLayer and not the table.
How do I get it to write to the table? I need both the featureLayer and the table in the service becasue they have a relationship set up.
JamesTedrick
Esri Esteemed Contributor
Hi Nick,
You need to specify the table you wish to write to by providing the layer's name in the form_id entry in the settings workbook.
SamEdwards2
How did you make the table have ID:0 and the FeatureLayer is ID:1?
JamesTedrick
Hi Sam,
When publishing via desktop, you can have the IDs set to specific values, rather than automatically assigned:
Map authoring considerations—Documentation | ArcGIS Enterprise
SamEdwards2
Thanks for this info.
So I had success in that was able to publish a line layer (Pipes) with a related table to AGOL, with the table ID = 0 and the Pipes ID = 1 (which then allowed me to add the service URL as the submission URL in my s123 form, and submit data from s123 to the table.
Thinking I was in the clear, I am now finding that when I publish the Pipes/table feature service (4 pipes in the line feature class, and no records in the table), for whatever reason, the 4 pipes disappear once on AGOL - no geometries display, nor are there any features in the pipes attribute table. WHY?
In a webmap, I am able to add pipes to the layer, but for whatever reason, when I publish from desktop to AGOL, it somehow loses my existing pipes. Perhaps has something to do with changing the IDs around?
JamesTedrick
Hi Sam,
On the display in the ArcGIS Online, I do not know the issue involved with this- it would be best to raise that in their groups.  That being said, I'm not sure why the reordering of the layers is necessary.  Survey123 can write to a table even if it's layer id isn't 0 - the table name needs to be specified in the form_ID entry in the settings worksheet.
SamEdwards2
I did not reorder the IDs initially (Pipes ID = 0 and the table ID = 1), and I could not get s123 to publish the survey. Again, I published a pipes layer and a related table to AGOL, and below is a snip from that Feature Service's URL...
http://services.arcgis.com/0hWR1h1PHFoPztOo/arcgis/rest/services/surl_pipes0/FeatureServer
So, in an effort to populate a submission URL specifically for the related table, I used the following URL (note the "/1" at the end to point directly to the table, and not the pipes):
http://services.arcgis.com/0hWR1h1PHFoPztOo/ArcGIS/rest/services/surl_pipes0/FeatureServer/1
The following is the result when trying to publish my survey:
My next thought was that adding the "/1" is what is fouling things up, so I replaced the above submission URL with the following (simply excluded the "/1"):
As a result, I was able to publish the survey, but when trying to submit a survey, I get the following error:
This led me to believe that  by using this URL (http://services.arcgis.com/0hWR1h1PHFoPztOo/ArcGIS/rest/services/surl_pipes0/FeatureServer) and not specifying a layer ID at the end, s123 looks at whatever layer in the feature service has an ID of 0 (in this case, the pipes), hence "incorrect geometry" error.
So, that is why I tried switching the IDs around so the table is 0 and the pipes 1 when publishing the feature service, thinking a submission URL requires no "/#" appended to the end. And like I said before, doing this allowed me to publish the survey and submit data, but when publishing the pipes/table feature service, I lose the features in my pipes  on AGOL.
Maybe I am going bout this all wrong - I'm sure there is a way to populate the submission URL to write to a table regardless of its ID, but what am I doing wrong? How can I populate the submission URL with a valid URL that points directly to my related table that has an ID of 1, or any number for that matter?
Thanks for your responses thus far, I'm really hoping I can get this to work as I foresee a large time-savings by submitting survey data to a table that has a relationship already in place with the pipes layer.
Sam
JamesTedrick
Yes, there is a way to specify which layer the form is writing to - specify the name of the layer in the form_id entry of the Settings tab in the XLS file.  For example, looking at this service:
A form targeting the table only has this setting:
