Is there any way to enable "Ignore SSL Errors" in Survey123 connect?
I need to connect Survey123 with Portal for ArcGIS while my current certificate is Self-signed certificate.
Ismael Chivite
James Tedrick
Thanks in advance,
Khaleel
Hi Khalil,
If your ArcGIS Enterprise is using a self-signed certificate, you can add that certificate to your devices' trust store to enable access. Alternatively, you may want to get a trusted SSL certificate for your computing environment- see Configure HTTPS using a new CA-signed certificate—ArcGIS Server Administration (Windows) | ArcGIS Enterprise
Thank you James.
Khalil,
James Tedrick I'm running on Windows and I installed my certificate to the Trusted Root Certification Authorities but I'm still getting the error.
Hi Chris,
To confirm, you are able to view the Portal website without SSL error in IE/Chrome on the same computer?
