Survey123 will not be sent until the map is clicked.
384
08-04-2022 04:48 AM
HansvanBuggenum
I have a Survey123 form with a mandatory geopoint question. When you activate the map as a user, the marker is placed in the map. Until recently you could then send the form. That suddenly no longer works on certain Android versions. Error message is: 400: Unable to complete operation.
Now you must click in the map and then you can send the form. It seems to be an Android specific problem. On an Apple device, activating the map is sufficient and you do not have to click in the map.
Does anyone know this?
As a work around I want to make clicking in the map mandatory (for now). Is that possible?
