Survey123 Web Author Images
751
11-20-2017 11:05 AM
TiffanyRufo
Occasional Contributor II
I am trying to publish a public survey with multiple note fields containing images through Web Designer. Initially The images were too large and I received the error when trying to publish. I fixed all of the images: all are now under 10KB in size. However, I still cannot publish the survey... Any advice or ideas on what I am doing wrong here?
  • Designed survey in Survey123 Web Designer
  • 23 note fields with text and image (under 1000KB)
  • 2 select one questions.
  • Tried to publish:
    • Get the following error :
Version:1.0 StartHTML:000000238 EndHTML:000459245 StartFragment:000455287 EndFragment:000459170 StartSelection:000455287 EndSelection:000459170 SourceURL:http://survey123.arcgis.com/surveys/e0b327ab7a044e3d964fe41921b1aaf7/designP.R.I.D.E Award Voting - Design
"Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/3385285611e447c8801e160ddb27ef34/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/be5d4b5458c441d4b7da58d75d31da96/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/796d5846688d4c72b1f6cc154b6e06f9/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/2d771bb70d0a414ca386eb781d2aca7d/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/2f639337bb8e4a8783ac68ce2d56597f/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/5bd183ba72bf44e9b0f787a1ab350b4d/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/1d6b7bdd7af04737a3a2a3dd43b6a81f/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/0cd671a214244caaa4ba22c818642fbc/data' because Unexpected response from the remote host."; "The file exceeds the max. size 1,000KB"; "The file exceeds the max. size 1,000KB"; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/f33651e1f17b4465a05ef82430e79e30/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/595f634ea586437ba7bf0f769c07efb2/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/217ec0500e274625a0fe98c44bfd12bd/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/085c4cdb6e3645409fb833bf80577563/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/6bd2d3c4022343719e2e985682abb1fb/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/6ea0dfad9e41415bbe90417112af7aa1/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/1770ec684a2146f89c593695379f717b/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/5416d8b3d83349198e5e1b90aeaf48af/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/9a8785547b1243b7b3694bb8aa59fe56/data' because Unexpected response from the remote host."; "The file exceeds the max. size 1,000KB"; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/cc9961d283ac4c08b873f03e0017b322/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/0fe867247d8d439aae3af2f2661f6a9c/data' because Unexpected response from the remote host."; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/bf9195d571654f62bd3bef7f2e0ee372/data' because Unexpected response from the remote host."; "The file exceeds the max. size 1,000KB"; "Can not download image: 'http://ecgisab.maps.arcgis.com/sharing/rest/content/items/89a43eb95e6a4183a45e95a3cacffd04/data' because Unexpected response from the remote host."; "The file exceeds the max. size 1,000KB"
Using Edge Browser
TiffanyRufo
Well, so far as I can figure it out myself...I had to re-design the survey from scratch and used the following workflow:
  • Create the note
  • Title it
  • Add the re-sized image (under 900kb)
    • MAKE SURE THERE IS NO SPACE BETWEEN THE IMAGE AND THE TOP OF THE TEXT BOX
  • Add the description above the image (again making sure there was no space between the text/top of text box/image
  • Publish the survey
Repeat 23 times.
TiffanyRufo
  • Create the note
  • Title it
Repeat 23 times.
