Survey123 Updated Form Will Not Publish
24688
30
04-16-2018 05:57 AM
JoshHabel
I am having an issue updating an existing survey.  Below are the 3 items I changed.  Not sure why it is not publishing.  I have not added any new fields or choices.  Hoping that someone can shed some light on this.  I just finished creating several maps, apps, and a dashboard the pulls from this forms feature service and I would hate to have to recreate all of that to make these simple changes.  I have attached both the working form and the modified form that won't publish.
1)   I  added back a pull data calculation to the "Inspected_By" field that I had previously deleted and also made it required.
2)   I changed part of the calculation for the "maximum" field.
3) Changed case of 'OK' to 'Ok' in calculation for "Inspection_Priority" field.
Any ideas as to what the issue is would be very much appreciated!
Josh
KristenMeier
I am having a similar issue. I'm trying to publish an update to an existing survey, we are adding a few fields but I wouldn't think it would create such a problem. There is no error message given the process just seems to be stuck. We did not add anything new to our choices tab and the survey published fine before, not sure what the hang up is?
