Survey123 Thank you screen with dynamic fields from feature service
909
09-11-2023 01:04 AM
r_povilaityte
I have a feature service with data from PostGres DB. There is also a sequence which with the help of an attribute rule creates Unique ID for each record.
I am using this service with a Survey created in Connect. Survey is designed to report problems in the city. Unique ID is generated so that users can later check the status of submitted problem.
What I would like to do, is use this Unique ID field in Thank You Screen. However, the ID is generated only while inserting new record so there is no way to have it in Survey form prior the submit. So basically, there is no way to inform the user of problem ID that was given to his reported problem.
Since there is possibility to get globalId in Thank You Screen with @[globalId] syntax, maybe there is a way to also get other fields from feature service?
Unfortunately, creating "Ticket Numbers" with uuid() or formating date is not acceptable to us.
abureaux
MVP Frequent Contributor
Sorry. Not aware of a way to incorporate GlobalId into the Thank You screen.
Have you considered a Thank You email? May or may not work for your workflow, but would definitely be able to display the GlobalId.
r_povilaityte
You can use GlobalID in Thank You screen, using @[globalId] 😊 But we need to use more simple IDs, like 1,2,3.. with a prefix., which we get from attribute rule.
Email would be a solution but in our case we allow anonymous reporting 😕
AnushaRanga
I was able to display globalid=@[globalId] on thank you screen. Is there any way that we can display objectid or uniqueid on thank you screen.
