Survey123: Split the address number from street name?
1217
05-23-2019 09:20 AM
JordanMiller4
How do I split the address numbers from street names and move that data to another field?
JamesTedrick
Esri Esteemed Contributor
Hi Jordan,
How are you receiving the street address?  If it's coming from a reverse geocode, you should be able to request the specific subcomponent (see the 'AddNum' value in the sample at Geopoints—Survey123 for ArcGIS | ArcGIS ).  If you are trying to parse text entered in a form question, that could be more difficult.
JordanMiller4
Hi James,
I see there is a something for getting the address numbers but there isn't anything for the street. I figured I would need to somehow remove the everything before the first space which would remove the house number.
JamesTedrick
Hi Jordan,
It may help to see the response first - street name may be in the response.  The World Geocoding Service documentation (geocodeAddresses—ArcGIS REST API: World Geocoding Service | ArcGIS for Developers ) shows it in the response.
