Survey123: Run Report like other ESRI apps?
764
06-15-2018 10:38 AM
AlexP_
I wonder do ESRI apps have like Survey123 that is run a report? Please advise!
Thank you!
by Anonymous User
Not applicable
Hi Alex,
Can you please expand on what type of report you would like to run? The survey123 website supports the reporting information collected via the survey123 app or web form by the use of the Analyze page, Data tab and also printing via Individual Response and Custom Template Reporting. Is this what you are after?
Phil.
AlexP_
Hello Philip,
Thank you for your response. I have web map with web appbuilder from arcgis online. I would like to have these same custom template reporting as survey123 has.
by Anonymous User
Not applicable
Hi Alex,
The custom template reporting is only available in the Survey123 website at present, which requires having a survey form item to be able to run the report. You could look at creating a survey based on the existing feature service you have for your web map.
Phil.
