Survey123 REST API: how to get a token? featureLayerUrl?
3521
04-22-2021 11:04 AM
JoseVidal
I am trying to use the feature report API but the documentation at that link does not tell me how to authenticate.
According to that page, to get a sample report template (just testing) I have to do:
Is the token value the API key I can generate from following this documentation ? So, token==API Key? if not, how do I get a token?
How do I get the featureLayerUrl for my survey123 survey that I just created?
All I am trying to do is to create a simple survey with survey123 and then generate and fetch one of the reports it can generate using the REST API.
KerryKang
You can extract token in the survey form.
Use this in calculation..maybe set the type as hidden and esri type null.
pulldata(‘@property’,’token’)
kerry
JoseVidal
Thanks!
Does anybody know how I get the featureLayerUrl?
KerryKang
Hi Jose,
You can get the feature layer url on the layer's overview page. At the bottom right, there is a url you can copy.
Kerry
