Survey123 reports in Enterprise
2336
05-16-2023 02:02 PM
ZenMasterZeke
Hey ESRI folks,
Do you know anything about the status of adding reporting capabilities to Survey123 in Portal/Enterprise? I see it's been 'Under consideration' on the Ideas page for over a year and a half. Thanks.
IsmaelChivite
Esri Notable Contributor
Hi @ZenMasterZeke  Still in our road map and under development. 2024 delivery at the earliest.
IsmaelChivite
GIS_Fox
Hi @IsmaelChivite , will organizations migrating to Enterprise in the interim lose the ability to generate reports for Survey123?
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
IsmaelChivite
With some limitations, you can use the ArcGIS Online report service today with your ArcGIS Enterprise data.
Limitations:
  • You must configure a web adaptor in your DMZ so the ArcGIS Online report service can securely access your data in ArcGIS Enterprise (Integrated Windows Authentication is not supported).
No ArcGIS Online credits will be consumed when you combine ArcGIS Enterprise with the ArcGIS Online Report Service.
If this hybrid approach does not work your organization and you want to deploy your Survey123 report service locally within your own infrastructure, please vote up and add your comments to this ArcGIS Idea. Including the Survey123 report service with ArcGIS Enterprise is in our road map, but it will only be available in 2024 at the earliest.
SvivaManager
Hey, @IsmaelChivite  is there a guide, video or documintation on how to combine the report service with the enterprise survey123 website?
can you post the ArcGIS Online report service url?
KacperMaslowskiUMG
Hello! As 2024 is ending, are the reports for Survey123 in Enterprise going to roll out anytime soon?
Asking because our organization migrated to Enterprise from AGOL, being told by local ESRI representative that this problem will be solved this year. Reports function is pretty important to us.
