Survey123 report template: return count of question within a nested repeat using if statement
2056
06-29-2022 09:45 PM
CharlottePeters95540
I have a survey form with nested repeats structured as:
  • Project
    • Plot (repeat)
      • Feature (repeat within Plot)
        • Survey type (question)
        • Rating (question)
I created a report template that will provide totals for all Projects surveyed in a year.  Part of the report contains a section that tallies the # of different ratings (e.g. excellent, good, etc.) for each survey type (e.g. CB, CD, FB, etc.).
If a survey type does not exist for a particular year then I want the ratings table to be hidden on the report.
I've tried using:
${#rptFeature}${if SurveyType=="CB"}
Survey Type
CB
# of Features Monitored
${rptFeature | where:"SurveyType='CB'" | stats: "count,objectid"}
# Excellent
${rptFeature | where:"SurveyType='CB' and FeatRating='excellent'" | stats: "count,objectid"}
etc......
etc........
# Failed
${rptFeature | where:"SurveyType='CB' and FeatRating='fail'" | stats: "count,objectid"}${/}${/}
also tried ending with ${/}${/rptFeatures}
but end up with a table being repeated for each of the selected survey type records
If I remove ${#rptFeature}${if...}....${/}${/} and use the following syntax, I get the correct totals for each survey type.
Survey Type
CB
# Excellent
etc....
etc....
# Failed
However, if the survey type does not exist (i.e., FB), the table for that non-existent survey type still persists in the report.
I cannot seem to get the syntax right for creating a table that tallies the total ratings for each existing survey type from the nested repeat. Any suggestions?
I'm using Survey123 Connect v 3.14.281 to create the form. I'm attaching my xlsxForm, report template, and 2 generated reports with different survey type scenarios. I've pared down the questions from the original to focus on the trouble spots.
