I am trying to create a report that will put the repeats in a table row by row (this works fine), but then I want to place the pictures that are taken within the repeats at the end of the table. I think I am following the syntax examples correctly. When I try to load the report template with the photos portion, it gives me an error ‘Failed to parse ${photos} since field name or parameter photos cannot be found in the current parsing scope’.
When I do it without the photos portion, it works fine. Probably a syntax problem but I cannot figure it out. I have attached some screen shots and the xlsx form and report template.
Using Connect 3.10.323
Thanks, Elizabeth
