Survey123 relevant requirements not working in web application
809
05-26-2020 11:02 AM
BillJacobs
I have a survey published using Survey123 connect. I have several required fields, but they have relevant constraints. For example, if someone has a crossing type of "bridge adquate", the field is not required. All else, it is required. This works just fine in the mobile application, but, in the browser, if I select this crossing type, it still throws errors because I haven't filled in the required fields.
Advice?
Thank you!
JamesTedrick
Esri Esteemed Contributor
Hi Bill,
Apologies for the delay.  I'm not able to reproduce the behavior you are describing with a simple form.  Could you open a support ticket with Esri to determine what in your form design is leading to this issue?
