Survey123 - Public Permission Issues
1982
02-06-2018 05:42 AM
AntonioSaavedra
Good afternoon!
I created an Online Survey in Survey123 https://survey123.arcgis.com/share/f616ee2999d44d5ea9f691c46b55a1a4 , to be completed by anyone (public). I then created a web map via Survey123-Data-Open in Map Viewer, also available to the public to view http://bit.ly/2EL9skE. Even though, I have share the web map and web application, users are getting challenge and the login screen to my account appears on their phones. Is there is anything that I can do to prevent this?
Thanks
Tags (1)
AntonioSaavedra
I share the survey from both sides. Need to read about _stakeholder view of the feature service.
JamesTedrick
Esri Esteemed Contributor
Hi Antonio,
Did you share via the Survey123 website or ArcGIS Online?  If you shared from the Survey123 website, you need to use the _stakeholder view of the feature service - that is what is publicly shared.
AntonioSaavedra
AntonioSaavedra
James,
Thanks very much for the information, it fixed the problem. You rock!!!
Antonio
AntonioSaavedra
James,
Antonio
