Survey123 Phone number key enforcing
697
06-21-2023 01:13 AM
AbdelrahmanGhazaly
Hello,
In survey123 connect I'm trying to enforce user to enter his phone number starting with code (+99) but in the input mask field it determines the 9 as any value from 0-9 is there a work around for this ?
Abdelrahman.
ZacharySutherby
Hello @AbdelrahmanGhazaly
You will need to use the backslash (\) to escape the 9's in your country code. For example, (+\9\9)999-9999 will yield  ZacharySutherby_0-1687389941038.png and when you start typing the numbers entered will be after the end parenthesis. Please see this documentation for more information.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
