I get the following error message when attempting to update my survey. The Alt(altitude) field was published in the original survey without issue for a geopoint. Not sure how to fix the issue. As I am collecting this for a series of photo repeats as well. Only the geopoint related field is causing this issue. I have found a solution.
Hi Damian,
Please share your solution on the forum, it will become a valuable resource for others who encounter similar issues.
Brett
Hi, I'm getting the same error. This was working on my previous survey, and now it's not. Any Updates?
Turned out to be a switch from Integer to Decimal for me.
