Survey123 Keypad with decimal field does not accept '.' but accepts commas ','
1568
08-17-2023 04:40 AM
Veronica22
Hi
I have created a survey using survey connect Version 3.18
I am unable to input decimal separator as (.) on a Survey 123 keypad, it only accepts a comma ( , )
The workaround below does not solve the problem.
https://support.esri.com/en-us/knowledge-base/problem-unable-to-input-decimal-separators-in-the-arcg...
Changing the windows regional setting to decimal symbol (.) does not fix the issue.
Veronica
DougGreen
I have been having "device keyboard" issues similar to this. It will behave differently on different devices (iPhone, Samsung-android, Google-android). Can you verify that this is happening on all types of devices?
Veronica22
Hi @DouglasGreen
The issue seems to occur on all devices. We tested on iPhone 12 Pro Max other users have tested it on Samsung phones as well as other devices it still occurs.
JerminahBoshego
Hi
Have You Found a solution for this? I am experiencing the same challenge on iPhone 13 and Samsung-android tablets.
A solution will greatly be appreciated.
DougGreen
Not yet...
