Survey123 - Is it possible to auto populate a 'select_one' type based on two previous questions that are 'select_one' types as well?
For example - I have two "yes or no" select_one questions (fields: NEED_IND and DELETE_CORNER.) If the answer to both of those questions is 'No', then I would like to auto populate the subsequent select_one (field: TYPE_CD) question with the value 'Not Needed.' Is this possible?
Please see attached. Thank you!
-Casey
