Survey123-Integromat Extract email value
785
02-10-2020 06:40 AM
GeorgeFloros1
New Contributor II
Hello,
I have been able to connect Survey123 and Outlook via Integromat and I can successfully send an email when I enter the email address manually.
In my survey, I have built it so the user can select from a pre-defined select_one list the email address he wants to forward the survey to.However, Integromat does not read the value/label (i.e the email address) but reads the "name" of the choice(i.e. approvalpersonA). As such it fails.
Any ideas on what am I doing wrong?
Thank you,
George
Jim-Moore
Hi George
As you've discovered, a survey's webhook payload will only contain the name (domain value) for a selected choice, not its label. This is by design (the underlying data in the feature service is sent by the webhook).
A workaround for this is to use the jr:choice-name function to write the label of the selected choice to a (hidden) text question. You can then access the answer text question in Integromat.
For example, for a select_one question called "email" you could use a calculation like:
jr:choice-name(${email}, '${email}')
More on this function here:
Formulas—Survey123 for ArcGIS | Documentation
XLSForm essentials—Survey123 for ArcGIS | Documentation
Cascading and external selects—Survey123 for ArcGIS | Documentation
Hope this helps
Best,
Jim
GeorgeFloros1
New Contributor II
Thank you Jim! Exactly what I was looking for!
Kind regards,
George
