I'm having trouble installing Survey 123 Connect, the desktop version, windows x64 version. When I run the .exe it shows the screen in the attachment. There's no 'next' button, so I can't continue the install.
What's causing this and how can I fix it?
Hi Vincent,
What version of OS are you using and what locale is your OS set to?
The app shows Dutch as installation language.
I can see the buttons with the same build(3.7.62) and my locale is Nederlands(Nederland) on win10.
I'm on Windows 10 as well, Windows 10 Pro 64 bits build 17763, Dutch (Nederlands) language.
Hi Vicent,
Could you check your desktop device specifications(Settings>System>About>Device specifications)?
And also check if you have latest graphic driver updates on your desktop?
Device specifications look the same as yours.
Graphics drivers are up to date.
Could you try on another machine to see if you are still seeing the missing buttons issue?
Hmm, it does work on other machines; I asked some colleagues. They do have the same model laptop and same installation, so that's a little odd... Mine's also the newest.
Thanks for the help so far, by the way.
Signed in members can post, follow updates, and more. New here? Register a free account.
