Survey123 inbox query repeat not stable
3852
10
06-24-2020 10:11 PM
לאוראורשן
We built a form that contains repeat and enable in the inbox mechanism to return to existing records with an update capability. We use parameter query "query allowUpdates=true" for the repeat and the fields that are included in it. All worked well, and suddenly about 2 weeks ago it stopped showing the repeats that were entered and submitted in the past. We made some changes to the "allowUpdate" query and it worked fine for several hours, and then stopped working again. We have no idea what is the reason and how to make it work again. The excel form of the survey is attached.
Hope that you can help us
Guy and Laor
DarraghOSullivan
Hi again guys,
I also tried to re-build the second survey that uses Inbox but exactly the same. Any ideas?
