Survey123 Inbox for repeats not displaying map view option
1019
06-03-2020 11:06 PM
ellieroh1
Hello, I'm working on a survey for equipment inspections that includes related records using
  • repeats
  • the Inbox
  • a survey geopoint
The Map and List view options in the Inbox don't show up - my understanding is that if I have a geopoint in my survey, they should but they don't...(see image below).
In Survey123 Connect, I have:
  • maps = Basic (I tried setting them to Standard - that didn't resolve the issue)
  • query expression = none
  • spatial filter = enabled
In the XLSform, I have the geopoint set to:
  • required = yes
  • appearance = hide input
Is there a setting that I'm missing in Survey123 Connect and/or in the XLSform for the geopoint?
-- Ellie
Survey123 inbox with repeats (for related records) not displaying Map or List view options
survey inbox‌ survey123 inbox‌ survey123 geopoint survey123 repeats #Survey123InboxRepeatsMapView
JamesTedrick
Esri Esteemed Contributor
Hi Ellie,
Apologies for the delay in response. For current Survey123, there needs to be a geopoint question present in the form for the map option to be displayed.  I'll note that this has been revised for the next release of Suvey123; you can preview this through the releases available in the Early Adopter Community.
