The image-map question type is quite useful for quickly populating a string field with outputs from clicking on zones in an svg using the select_multiple option (e.g. risk matrix example). We would like to also capture the graphic results from the completed question as an image (jpg/png) attachment. The actual graphic output is very helpful for capturing lots of information that can be absorbed at a glance. Short of taking a screenshot of the completed image-map question and adding it as an attachment, is there another way to do this within Survey 123. We want to have the image included in the output report.
