Survey123 if statement calculation
2548
10-20-2023 07:33 AM
ChristopherMask
Good Morning Community,
Again, I know this shouldn't be hard, but I can't get the calculation to work using an if statement. Could someone help with the name columns Two09 and Two09Calc. It currently has this for the calculation:
if(${FinalFireAcreQuantity}>='300','Yes','No')
Also, I would like to add a condition for NumberFatalities >=1 to the if statement.
If statement is true, then Two09 = Yes, if not Two09 = No.
Katie_Clark
MVP Regular Contributor
I think the issue might be that you are trying to use a comparison operator ( >= ) on a string ( '300' ). What is the field type of ${FinalFireAcreQuantity}? If it's a number type, try removing the quotes around 300 and see if that works.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
ChristopherMask
Goodness, that worked! Thanks for the response and have an excellent weekend!
Also, added more to the statement. if((${FinalFireAcreQuantity}>=300 or ${NumberFatalities} >=1), 'Yes','No')
Christopher
PavlovaVitale
on what type of column do you put the if statements?
Katie_Clark
@PavlovaVitale In a case like this, it should go in the Calculate column
Best,
Katie
