This is the Grid Style Groups Sample from Survey123 Connect, viewed on an iPad, has anyone found a fix for the stacked answers? Thanks in advance!
Solved! Go to Solution.
I found the issue -
The iPad needs to be in a horizontal position to match the grid layout. The field tech had it in a vertical position.
I did not have an iPad during this question.
I'm leaving the question here in case someone else has this issue.
I found the issue -
When I opened my working survey my answers were still overlapping, I found that if I removed all the w1 from appearance the text stopped overlapping.
I also forced a couple of blank spots, buy added EmptyA & EmptyB.
