Survey123 geopoint map not visible when using relevant filter
2495
10
12-03-2024 11:23 AM
AmyAlford
I created a survey through Connect. I added a filter (${site_list="~NEW"} such that the geopoint question is only visible when a new location is being entered. However, the 'map' interface isn't visible in the survey. One must click on the AmyAlford_0-1733253567739.pngicon to render the map in a new window. I tried several iterations to see where the issue is coming from and it appears to be only when there is a relevant filter set. I've attached an example xlsform. I'm using v3.19.
AmyAlford
Thanks for this information. The default "position" does fix the map appearing issue. But you are right, it is a bit of disaster with the Inbox. When using the Inbox to edit a feature from a feature service, it adds a second feature instead of editing the original feature. This was not the case without default "position". It works how I would want it to when adding NEW locations, however.
Will have to settle for users to click on a button. Not always ideal, but adding a required parameter helps them not forget.
